 LUIS SÁ SILVA
Ir à página : Anterior  1, 2, 3 ... 10 ... 18  Seguinte
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Jan 22, 2009 1:38 am
OLHA LUIS FOI MUITO BOM TERES APARECIDO DOMINGO NA ESCOLA, AS CRIANÇAS NÃO FALAM DE OUTRA COISA, PRINCIPALMENTE A ALBERTA, ACHA Q FOI MUITO BOM TDO Q EXPLICAS-TE ACERCA DAS TRAJECTÓRIAS, CONTA ELA Q FICOU TDO MAIS FÁCIL E JÁ PENSA EM PREPARAR-SE PARA SER A MELHOR DA ESCOLA.
A MAFALDA DIZ Q QUER CHEGAR ATÉ A FORMULA, ESTA TODA RADIANTE.
DE CERTA FORMA FOI UM GRANDE ESTIMULO ESPERAMOS Q ESTA NÃO SEJA A ULTIMA VISITA.
PQ É SEMPRE BOM OUVIR DICAS DE PROFISSIONAIS.
UM ABRAÇO MEU PUTO, MANDE SEMPRE E OLHOS NA FORMULA UM
Joao Coimbra
Número de Mensagens : 95
Idade : 66
MensagemAssunto: Northern European Cup 2009 - F. Reanult 2.0   Dom Mar 29, 2009 8:49 pm
[size=18]Meus caros
A partir de amanha vamos prestar um pouco mais de atencao a este Campeonato. Pode ser que apareca por la uma bandeira de Angola.
Who knows??[/size]
News
Northern European Cup enjoys successful tests at the Nürburgring
Having a full field of 24 cars, the Northern European Cup can look back at two successful days at the Nürburgring, Germany. Wednesday 18th and Thursday 19th of March offered Formula Renault 2.0 the possibility to use the Formula One track and prepare for the coming season.
Making good use of the nice weather, Magnussen and Motopark Academy put the fastest time on the screens (1.57.625) on Wednesday. Finnish Toomas Heikkinen, driving for Koiranen Bros was well able to keep up by being only seven hundreds of a second slower than Magnussen. The remaining part of the top five was made up by Felix da Costa and Jacobo for Motopark and a good result for Nigel Melker with MP Motorsport on 5th place.
Thursday started with grey skies, but in the morning already gave way to an improvement of the set record. The son of former Formula 1 driver Magnussen beat his own time by three tenth of a second (1.57.312). A time that would stay put for the rest of the day. Whilst the constructions on the immense new grand stand constantly progress to be ready for Formula One, the day on the track finished with good results for Quaife Hobbs in 2nd place (1.57.469) and Arnold Neveling,(1.57.959) for SL Formula, being the fifth fastest driver on the track.
The next official test for Formula Renault 2.0 NEC will take place at the famous track of Hockenheim, on the 30th and 31st of March, 2009. This will be the last test before officially starting the season with the Easter Races at Zandvoort (11 & 13 of April, 2009).
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 07, 2009 4:02 am
Ora o João Coimbra é um homem com muito boas fontes.
Esta da participação de um angolano no NEC estava guardada entre sete chaves porque não convém "abrir a boca" antes que tudo esteja seguro.
Mas já podemos anunciar que o Luís Sá Silva chegou a acordo com a equipa Krenek Motorsport e vai participar no Northern European Cup.
A competição compreende oito eventos de duas corridas cada, disputa-se em circuitos da Alemanhã, Bélgica, Holanda e República Checa.
O jovem piloto testou em Hockenheim nos dias 30 e 31 de Março p.p., como preparação para o início da época que tem lugar nos dias 11 e 13 de Abril próximo em Zandvoort na Holanda.
No primeiro dia o piloto de Angola ficou no 19 lugar entre 26 participantes tendo rodado em 1:42.050, a 4 segundos do melhor registo do dia que coube a Felix da Costa.
No segundo dia de teste o Luís melhorou o seu tempo, tendo ficado em 13 lugar na tabela do tempos, com uma volta de 1:40.676, a dois segundos de Nigel Merhi que rodou em 1:38,425.
Timo Rumpfkeil, dono da Motopark Academy, equipa que tem a supervisão dos treinos do angolano , referiu no final que: “I believe that since Luis did not drive since December he did a very good job. You have to consider that all drivers present at the test already have done a serious amount of testing in 2009 and as well knew the Hockenheim circuit. We are confident that we can help Luis to close the gap quite quickly with more testing”.
O Luís tem outro projecto ainda para este ano e poderá em breve trazer novidades.
Quanto aos treinos em Hockenheim posso dizer que o piloto considera que poderia ter estado melhor se não tivesse feito uma viagem de mais de 13 horas e não estivesse a sentir a diferença no fuso horário (menos 8 horas).
Abraço a todos.
___________________
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Sab Abr 11, 2009 4:05 pm
Luís Sá Silva vai participar também no Campeonato Asiático de Formula Renault de 2009.
Os patrocinadores entendram que o jovem piloto deve rodar o máximo possível para que em 2010 esteja apto a lutar de igual para igual com a concorrência eurpeia.
Nesse sentido vão apoiá-lo para que possa estar nos dois campeonatos simultaneamente (NEC e AFR).
Haverá pelo menos um evento em que o piloto terá que optar em qual dos campeonatos irá participar porque são na mesma data as corridas do NEc e do AFR, bem assim como uma das sessões de testes colectivos do NEC que coincidem com corridas do AFR.
Estão em discussão os termos e a equipa com que vai correr na Ásia.
Em breve teremos notícias.
Saudações.
____________
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Abr 12, 2009 4:37 am
Caro Armindo manda noticias do Luis.
Hoje correu pela Krenek em vez da Motopark em Zandvoort na Holanda.
Fez o 19º tempo para a grelha entre 21 inscritos.
Terminou em 17º mas a 3 voltas do vencedor. Teve algum problema?
Se tiveres alguma foto coloca no Forum.
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Abr 12, 2009 6:53 am
ekuipa escreveu:
O Luís fará o NEC com a Krenek, mas com a supervisão da Motopark. O programa de treinos e troféus extra é que serão feitos com a Motopark.
Citação :
O Luís não terminou a prova devido a um despiste!
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Abr 12, 2009 7:17 am
Obrigado "expresso".
2ª feira há mais e pelo que sabemos o Luis este ano vai fazer muitas corridas ou seja muitos "kms". Vai haver mais despistes e vai haver muitas alegrias.
Papabeer
Sou da oipinião que este tópico deveria estar incluido no do Luis Sá Silva porque este ano ele vai fazer este Campeonato e o da Asia. Assim teriamos toda a sua carreira num só tópico e seria mais fácil acompanhá-lo.
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Abr 13, 2009 3:53 pm
Caro Ekuipa,
Obrigado pelo interesse e apoio que sempre tem demonstrado na carreira do Luís, aliás coisa que já vem de longe.
É verdade, não correu nada bem esta estreia do Luís no NEC.
Contudo, eu não esperava um resultado por aí além pelas seguintes razões:
1. Era a primeira vez que ele corria na pista de Zandvoort, ao contrário dos concorrentes e segundo me disse o André Couto é uma pista dificílima.
2. Com efeito, embora tenha feito dois campeonatos Asiáticos, os kms. que ele acumulou nessas duas competições não se comparam aos que acumulam em um só ano os adversários. A título de exemplo o Luís fez entre 2007 e 2008, 26 corridas, a maioria dos adversários fez só em 2008, 28 corridas (Eurocup mais WEC ou NEC).
3. Porque os apoios tardaram em aparecer o Luís esteve parado entre Dezembro de 2008 e o final de Março de 2009, enquanto os adversários testaram quase todas as semanas. Os adversários rodaram em média uma semana em cada uma das pistas onde se ia realizar o campeonato - sem esquecer que a grande maioria é repetente, ou seja já correram e testaram nas ditas pistas vezes sem conta.
Por último;
pegando nas tuas palavras e raciocínio ao referires-te ao Ricardo Teixeira no GP2, o resultado final talvez seja o menos importante. Importante são as cores de Angola aparecerem e o Luís fazer o maior numero possivel de kms.
Finalizando, se o Luís para o ano que vem, depois de um inverno pleno de testes e com muitos kms. em cima continuar a andar na cauda do pelotão, aí sim, eu começo a ficar preocupado.
Saudações a todos.
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Abr 13, 2009 5:18 pm
Obrigado Armindo, cá está:
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 14, 2009 5:07 pm
Infelizmente na segunda corrida o Luís foi colocado fora de pista por um adversário quando tentava ultrapassá-lo e os braços dianteirtas se tocaram.
Segundo o Luís ou tocava no adversário ou batia num muro, pelo que, nem havia por onde escolher.
Teria acabado em décimo caso não se tivessem tocado, pois o colega de equipa do Luís, bem mais lento e que sempre esteve na cauda do pelotão ficou no 13.
Na próxima corrida espero que as coisas corram melhor.
Já mandei umas fotos para o Ekuipa para que seja publicadas aqui.
Abraço.
_____________
Última edição por Armindo Sá Silva em Qua Abr 15, 2009 3:07 pm, editado 1 vez(es)
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 14, 2009 6:47 pm
As fotos:
MensagemAssunto: Re: LUIS SÁ SILVA   Sex Abr 17, 2009 10:53 am
Boas
Luís coragem, parabéns a família Sá Silva por mais um objectivo alcançado.
Saudações desportivas
Márcio Ruivo
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Sab Abr 18, 2009 1:02 am
Márcio,
Em nome do Luís e da família o nosso muito obrigado. É nestas horas que ele precisa de amigos e apoio.
Abraço.
Armindo Sá Silva.
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 28, 2009 1:17 pm
Continuando a nossa "política" de verdade e conscientes de que o Luís trava uma árdua batalha que exige dele muita calma e paciência, trago-vos os resultados das corridas de Honckenheim, dos dias 25 e 26 de Abril de 2009. http://www.necup.com/results09.htm
Nos treinos livres o Luís ficou em 15 entre 25 carros, rodando cerca de segundo e meio mais lento que o melhor tempo, mas com pneus velhos.
Este resultado representou uma melhoria pois nos testes colectivos de Março p.p., ficou a quase 3 segundos do mais rápido.
Nas qualificações um erro da equipa na pressão dos pneus ditou o 20 lugar entre 22 concorentes e uma saída de pista.
Na primeira corrida o Luís arracou bem, ultrapassou alguns adversáros e rápidamente se envolveu na luta pela 14 posição. A meio da corrida o carro começou a ficar instável e ele viu-se forçado a abrandar, perdendo posições e acabando em 18.
Chegou-se depois à conclusão que a equipa não fez uma obervação rigorosa do carro após a saída de pista nas qualificações, pelo que o carro estava desalinhado, facto que deixou o jovem piloto muito desapontado - esperava-se mais de uma equipa europeia!
Na segunda corrida o Luís arrancou bem novamente e estava a disputar a 12 posição quando em plena recta da meta levou um toque na traseira, em consequência, caiu até ao 19 lugar e depois foi recuperando até ao 14 lugar, posição em que acabou a corrida.
O jovem piloto vai fazer testes privados em 5 e 13 de Maio próximo com a equipa Motopark Academy e depois regressa à Macau para participar na primeira ronda do Campeonato Asiático de Formula Renault a ter Lugar em Xangai nos dias 22, 23 e 24 de Maio de 2009.
Saudações.
______________
Armindo Sá SIlva
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 28, 2009 8:45 pm
Boas noticias
Continuação de um bom trabalho
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Abr 28, 2009 11:14 pm
Boas
Isto é mínimo, faz parte da equipa, acredito que haverá melhorias na preparação do formula e a próxima será melhor, o mais importante é participar, nós já sabíamos que não seria fácil, faz parte do desporto, o mais importante é ele estar sempre motivado e optimista, acima de tudo ele concentrar-te nos seus objectivos, melhores provas virão.
Um abraço e força.
Márcio Ruivo
lusoroo
Número de Mensagens : 173
Data de inscrição : 22/11/2008
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Abr 29, 2009 4:29 am
vejo neste jovem a maior possibilidade de um angolano alcancar o palco mais alto do nosso desporto rei. Talento o Luis tem e bastante, os resultados e a maneira como o luis vem melhorando os tempos em pista assim o comprovam. um outro importantissimo ingrediente na carreira de um jovem piloto eh uma equipe de "management" eficiente e professional o que aparenta o Luis ja possuir.
Forza Jovem e Parabens ao team racing ss
Francisco Valadao-Duarte
P.S. uma ideia: que tal criarem o Luis Sa Silva Fan Club? quero ser um dos primeiros membros
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Abr 29, 2009 6:21 am
Eu tambem quero ser um dos priméiros
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Abr 29, 2009 7:56 am
Obrigado a todos pelo apoio demonstrado Wink
Lusoroo,
A ideia é boa! Mas mais importante do que criarmos um Fan Club, é termos pessoas que se interessam pelo Luís devido ao que ele vai fazendo, em vez de ser o Fan Club a impingir o "Piloto Luís" as pessoas que acidentalmente passem pelo Fan club.
Por isso, nesta altura, estamos 100% focados no processo de formação do Luís como piloto. O Marketing só virá depois disso...
Abraços,
Paulo Sá Silva
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Maio 06, 2009 1:43 am
Parabéns ao Luis, à família, aos seus amigos e patrocinadores.
O seu projecto tem todas as condições para singrar.
O que o Luís tem "unhas", disso, não duvidamos!
Sucesso e força, Angola!
MensagemAssunto: Novidades de hockneim racing   Qui Maio 07, 2009 4:34 am
5 de Abril de 2009.
O Luís S.S voltou ao circuito de Hockneim para treinar, mas desta vez sob a batuta da Motopark.
Mais confiante e satisfeito com o carro, mesmo utilizando pneus já bem coçados (método de treino) começou por conseguir melhor tempo (-0.2) do que tinha feito com slicks novos no último fim de semana de prova.
No final da tarde, colocou slicks novos e voltou à pista, mas desta vez a pista não estava 100% seca (chuviscava) e numa das curvas rápidas da pista os pilotos não podia dar 100% porque estavam bandeiras amarelas.
Ainda assim, o tempo voltou a baixar e coneguiu melhorar em 0.5 relativamente ao seu melhor tempo do fim de semana de prova.
Assim sendo, ficamos todos satisfeito por saber que o Luís continua a evoluir! Ainda não chegamos lá, mas temos razões para acreditar que é possível.
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 14, 2009 2:20 pm
Caros amigos,
Como uma das pessoas que traça algumas das linhas do projecto que envolve o Luís, peço-vos que não deixem de criticar quando acharem por bem, nem deixem de ser honestos quando escrevem neste espaço.
Não temos a veleidade de pensar que sabemos tudo e aqueles que puderem transmitir algo, passar uma ideia, uma dica, um caminho, uma sugestão e umas criticas, não deixem de expressar os vossos pontos de vista porque podem-nos ser úteis.
Temos tentado que este projecto assente em bases sólidas, com um rumo claro, procurando não queimar etapas para permitir o Luís crescer como piloto, perdendo o tempo que for necessário para aprender a conduzir como deve ser .
Por essa razão este ano recusamos muitas ofertas para o Luis correr em campeonatos e outras categorias que representavam dar um "salto maior que a perna" ou perdas de tempo com resultados duvidoso.
Daí a recusa em fazer Fromula 3, Formula Renault V6, Formula BMW, etc, etc
No dia 13 de Maio, portanto ontem, o Luís testou com a Motopark no circuito denominado Eurospeedway, na Alemanhã, realizando voltas de muito bom nível, dando mais uma vez provas de estar a assimilar os conhecimentos que lhe estão a ser transmitidos e a crescer como piloto.
Entretanto, acabamos recentemente de concluir nogociações com a equipa Art-motorsports e garantimos a presença do Luís também no Asiático de Formula Renault.
Fazê-lo correr na Asia novamente não era bem o que prentendiamos, mas obrigações conctratuais levam a que o piloto tenha de correr no continente Ásiatico.
Assim, nos próximos dias 23 e 24 de Maio, teremos o Luís na pista que lhe deu o primeiro pódio e a primeira pole position., Xangai.
Saudações,
______________
PJHO
Número de Mensagens : 316
Localisation : Luanda - Vila Alice (Angola) & Viseu (Portugal)
Data de inscrição : 24/01/2008
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 14, 2009 8:48 pm
Que tudo corra bem.
Pelas palavras que li, desde já admiro a união, honestidade, sinceridade e os valores da equipa familiar!
Têm mais um apoiante.
Força e muita sorte para o jovem Luís.
mcapela
Número de Mensagens : 49
Data de inscrição : 16/04/2009
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 14, 2009 10:19 pm
Parabens e força aí Luis, mostra ao basico do teu irmão como se conduz...
Grande Abarço á familia
cumps
MC
MensagemAssunto: Re: LUIS SÁ SILVA   Sab Maio 16, 2009 8:33 am
Boas
O luís vai correr ou treinar sempre a Alemanha? Ou tem outras pistas? É possível apresentarem o calendário das corridas na Europa ou possíveis treinos? Tenho algumas deslocações a Lisboa durante o ano, gostaria de ver se alguma delas estará na mesma data em que o Luís ira correr.
Terei muito gosto em vê-lo e poder tirar umas fotos para a minha colecção de pilotos nacionais.
Luís força e como sempre digo coragem, vais longe, continua a subir degrau por degrau.
Márcio Ruivo
MensagemAssunto: Re: LUIS SÁ SILVA   Sab Maio 16, 2009 8:39 am
Ó Capela,Razz
Twisted Evil Estás a encomendar uma tareia igual à que o NSX levou Question
MensagemAssunto: Re: LUIS SÁ SILVA   Sab Maio 16, 2009 8:51 am
Márcio escreveu:
Boas
Márcio Ruivo
Viva Márcio,
Os treinos do Luís serão quase sempre na Alemanha ou Macau. As corridas é que tb passam por Holanda, Finlândia, República Checa, China, Malásia e .........Portugal!
Por volta de Novembro o Luís estará em Portugal para mais uma vez participar no campeonato de inverno.
Quanto à prova na República Checa, achamos que o Luís ainda não tem idade para andar em terras tão "perigosas :Sing: " - Não vá o miúdo distrair-se com as vistas - Por isso estudamos a opção de eu substitui-lo nessa prova. Uma questão de maturidade apenas...
Como lá não há postes na pista, nada poderá travar a minha vitória king
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Maio 20, 2009 1:45 pm
Em primeiro lugar, mais uma vez um muito obrigado a todos pelo apoio que têm dado a este projecto neste forum. O Luís está a par de tudo e sei o quanto este vosso apoio e carinho lhe fazem elevar a autoestima e o sentido de responsabilidade.
Passo por aqui hoje para vos dar a saber que, doravante, o Luís vai fazer todas as restantes corridas do campeonato (NEC) com a Motopark Academy e não com a Krenek.
O nosso candengue ficou com os olhos a brilhar quando soube desta boa nova pois, ele melhor do que ninguém sentiu as diferenças entre as afinações de uma e de outra equipa.
Como lhe disse o pai Jorge: "Agora já não vais ter desculpas"! :Rir:
Abraços,
______________
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 28, 2009 12:08 am
Sá Silva entra com o pé direito na Ásia
O piloto angolano Luís Sá Silva iniciou da melhor forma o Campeonato Asiático de Fórmula Renault ao conquistar por duas vezes a 4ª posição na jornada de abertura disputada no Circuito Internacional
de Xangai, China.
Numa pista desfavorável à especificação aerodinâmica do seu monolugar - a última versão do Tatuus Renault – o piloto da equipa macaense Asia Racing Team demonstrou que esta temporada é um sério candidato ao título da categoria na Ásia.
Depois de ter sido o mais rápido nos Treinos-Livres, Sá Silva teve uma Qualificação infeliz, onde não conseguiu tirar partido dos pneus novos, acabando por largar apenas da 5ª posição.
Na contenda de 10 voltas de final de Sábado, Sá Silva fez uma corrida isenta de erros que o levou ao 4º lugar final,mesmo tendo caído uma posição na partida.
Na corrida de Domingo, o piloto angolano de 18 anos teve um arranque fulgurante que o levou ao 3º posto,posição que acabaria por perder ainda a meio da corrida, pois nas rectas longas do circuito de Xangai não lhe era possível suster atrás de si os concorrentesmais rápidos que dispunham da versão anterior do monolugar Formula Renault.
“O balanço do fim-de-semana foi positivo. A equipa fez um bom trabalho e o carro estava como eu queria. Dei o meu melhor para chegar ao pódio, mas não quis tomar riscos desnecessários. O meu objectivo é o campeonato e todos os pontos são importantes. Sabemos que podemos ainda melhorar, mas também tínhamos a noção no início da prova que este não era um circuito favorável para o meu carro. A próxima corrida em Pequim será diferente, pois é uma pista moldada à aerodinâmica do meu carro e quero lutar
pelas vitórias”
disse o piloto apoiado pela China Sonangol e pela China International Fund que este ano está a competir na Europa e na Ásia.
A próxima prova do Campeonato Asiático de Fórmula Renault decorre de 26 a 28 de Junho no circuito de Goldenport Pequim.
Para mais informações, não hesite em visitar http://www.art-motorsports.com e http://www.racing-ss.com
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 28, 2009 11:02 am
Paulo
E um bom inicio estar entre os 4 primeiros.
Luís parabéns e que continues bem concentrado nos teus objectivos.
Saudações Desportivas
MensagemAssunto: Re: LUIS SÁ SILVA   Qui Maio 28, 2009 11:50 pm
Viva Márcio,
Já é bom o 4º lugar, mas para este ano queremos muito mais por isso não estamos 100% satisfeito.
Por outro lado, nesta prova era muito difícil o Luís conseguir um resultado melhor porque tinha uma grande desvantagem aerodinâmica para os 3 primeiros: o carro dele fazia menos 12km/h no final da recta principal.
Entre os que corriam com o mesmo pacto aerodinâmico, o Luís foi o melhor e bateu inclusivamente o actual campeão da categoria!
Abraços e obrigado pelo apoio!
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Sex Jul 10, 2009 5:01 pm
Em busca dos triunfos
Luís Sá Silva quer subir ao pódio no fim-de-semana nas corridas de Pequim do AFR
O piloto angolano Luís Sá Silva participa no próximo sábado e domingo, em Pequim, na segunda prova do campeonato asiático de Fórmula Renault de 2009 com o objectivo de subir ao pódio. O jovem, radicado em Macau e que corre pela Asia Racing Team, classificou-se em quarto lugar nas duas corridas realizadas a 23 e 24 de Maio passado no circuito internacional de Xangai.
"Se tudo correr bem, o Luís pode ficar entre os três primeiros lugares na corrida de Pequim, mostrando que tem grandes possibilidades de se classificar bem no campeonato asiático de Fórmula Renault de 2009, onde se encontra actualmente no quarto lugar", considera o seu porta-voz, Armindo Silva.
Num comunicado, os responsáveis da Asia Racing Team consideram que, com apenas aquilo que se viu nas duas corridas em Xangai, "o campeonato de 2009 vai ser muito disputado entre o angolano Luis Sá Silva, o francês Benjamin Rouget e o piloto de Hong Kong Luca Ferigutti". A Asia Racing Team lembra, no comunicado, que o piloto angolano de 18 anos "vai a Pequim com a vontade de obter a sua primeira vitória no campeonato de 2009".
A competição integra ainda provas em Xangai no próximo mês, Chengdu em Setembro, Pequim em Outubro e Guangdong em Novembro. Participam na edição deste ano 21 pilotos da China, Estados Unidos, Hong Kong, França, Venezuela, Israel, Singapura, Indonésia, Japão, Angola e Austrália.
Em 2008, Luís Sá Silva, que começou a correr há três anos, classificou-se em quarto lugar no campeonato asiático de Fórmula Renault.
http://www.hojemacau.com/news.phtml?id=35333&type=sport&today=09-07-2009
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Jul 12, 2009 2:00 pm
Free Practice – Session 1
1- Alon Day – March 3 – 1.03.668
2- Benjamin Rouget – Asia Racing Team – 1.04.041
3- Zhi Qiang Zhang – March 3 – 1.04.146
4- Xiao Le He – Ghiasports – 1.04.681
5- Shan Qi Zhang – PTRS – 1.04.859
6- Tengyi Jian – FRD – 1.04.944
7- Luis Sa Silva – Asia Racing Team – 1.05.341
8- Luca Ferigutti – Asia Racing Team – 1.05.728
9- Chi Cong Li – PTRS – 1.05.841
10- Alexandra Asmaeopatra – Champ - 1.05.965
11- Samin Gomez – March 3 – 1.06.214
12- Pete Olson – FRD – 1.06.633
13- Chin Ka Lok – Ghiasports – 1.08.159
14- Guille Pintanel – Champ – 1.08.387
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Jul 12, 2009 2:01 pm
Free Practice – Session 2
1- Alon Day – March 3 – 1.03.793
2- Luis Sa Silva – Asia Racing Team – 1.04.014
3- Zhi Qiang Zhang – March 3 – 1.04.082
4- Xiao Le He – Ghiasports – 1.04.385
5- Benjamin Rouget - Asia Racing Team – 1.04.708
6- Luca Ferigutti – Asia Racing Team – 1.04.820
7- Tengyi Jian – FRD – 1.04.963
8- Shan Qi Zhang – PTRS – 1.05.335
9- Samin Gomez – March 3 – 1.05.779
10- Pete Olson – 1.06.172
11- Chi Cong Li – PTRS – 1.05.841
12- Chin Ka Lok – Ghiasports – 1.07.022
13- Guille Pintanel – Champ – 1.07.549
14- Alexandra Asmaseobatra – Champ – N/T
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Jul 12, 2009 2:02 pm
QUALIFYING
1- Alon Day – March 3 – 1.03.363
2- Benjamin Rouget - Asia Racing Team – 1.03.601
3- Zhi Qiang Zhang – March 3 – 1.03.956
4- Xiao Le He – Ghiasports – 1.04.987
5- Tengyi Jian – FRD – 1.04.056
6- Luis Sa Silva – Asia Racing Team – 1.04.114
7- Shan Qi Zhang – PTRS – 1.04.305
8- Luca Ferigutti – Asia Racing Team – 1.04.706
9- Pete Olson – FRD – 1.04.950
10- Samin Gomez – March 3 – 1.05.177
11- Alexandra Asmaseobatra – Champ – 1.05.527
12- Chi Cong Li – PTRS – 1.05.975
13- Chin Ka Lok – Ghiasports – 1.05.993
14- Guille Pintanel – Champ – 1.07.025
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Jul 12, 2009 6:49 pm
Primeira corrida: O Luis fez um bom arranque e passou logo para quinto. De seguida partiu para o ataque ao quarto posto e a meio da corrida, de dez voltas, estava ja em quarto.
Na luta para quarto o Luis perdeu algum tempo, pelo que, quando tentou o ataque ao terceiro ja era tarde, tendo ainda assim acabado muito proximo do terceiro.
Segunda corrida: Mais uma vez o Luis fez um arranque fortissimo e passou para terceiro. Entretanto o segundo cometeu um erro e o Luis aproveitou para passar para o segundo lugar, mas muito pressionado pelo piloto que seguia em terceiro.
Numa tentativa desesperada do terceiro passar o angolano acabou por embater na roda traseira do carro do Luis, levantou voo e foi embater forte num muro.
O carro do angolano ficou instavel e pois ficou com o eixo traseiro danificado. O Luis tentou manter o andamento forte que tinha imprimido desde o inicio mas acabou por fazer um piao (360), caindo para quarto, posicao em que terminou.
Neste momento ocupa a terceira posicao do Campeonato Asiatico.
Ao telefone o jovem piloto angolano confidenciou-me que queria dar pelo menos um podio aos angolanos na segunda corrida mas foi impossivel porque depois do toque que levou o carro ficou inguiavel. Disse tambem que o resultado final era positivo depois das complicacoes nas qualificacoes, pois na pista de Pequim quase nao se podem fazer ultrapassagens.
Saudacoes.
_____________
Armindo Sa Silva
Ps: Desculpem a ausencia de acentos mas o teclado nao os tem.
Última edição por Armindo Sá Silva em Dom Jul 12, 2009 9:38 pm, editado 1 vez(es)
MensagemAssunto: Re: LUIS SÁ SILVA   Dom Jul 12, 2009 9:17 pm
Luís os meus parabéns, para a próxima acredito que será melhor.
Márcio Ruivo
MensagemAssunto: Luis Sá Silva, corrida de Beijing   Seg Jul 13, 2009 2:27 am
Luis, meu Mano.
Aqui vái um Big Kandandu deste teu Camba, Kioko.
FORÇA MANO, estás a ir como deve ser, Já és grande e o nosso Povo já se pode Orgulhar de Ti, o futuro do nosso automobilismo no estrangeiro só passa por Ti.
FORÇA, PALANQUINHA VELOZ
Carlos (KIOKO)
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Jul 13, 2009 6:35 pm
Kioko obrigado pelo apoio.
Ja ha um topico onde as corridas do Luis sao comentadas, pelo que o administrador podia colocar este escrito naquele topico se nao achares mal.
O Luis pede-me para que te agradeca a ti e aos demais amigos todo o apoio que lhe tem sido dado.
Ele ainda so tem 18 anos e o apoio dos amigos deste forum sao uma grande ajuda.
Abraco.
Armindo Sa Silva
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Jul 13, 2009 7:34 pm
Ola, Armindo, meu Mano.
Não há Maca, Eu é que não sei o que fiz e que acabei por fazer um tópico novo.
Agradecer?.. não tem nada desses mambos, vocês como uma familia UNIDA praticamente sos e sem apoios já deram muito e continuam a dar, assim como estão a formar o "Palanquinha" para levar bem ALTO a BANDEIRA da Nossa AMADA PÁTRIA.-
Um Kanndandu
Carlos Kioko
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Jul 13, 2009 7:59 pm
Carlos meu Parente!
Eu sei bem que o que tens feito pelo nosso 'puto" é de coração.
Sei que esta "luta" do Luís também é tua.
Aquele abraço fraternal.
______________
lusoroo
MensagemAssunto: Re: LUIS SÁ SILVA   Seg Jul 13, 2009 8:28 pm
Parabens Luis por um excelente trabalho.
Mais uma vez confirmas que possuis todos os requisitos de te tornares um excelente piloto, contigo a possibilidade da bandeira Angola ser erguida no mais alto palco do desporto motorizado mundial, falta o apoio das empresas com visao.......
Que tal a SONANGOL reconhecer aonde esta o verdadeiro talento e parar de desperdicar fundos em condutores de taxi, porque acabar sempre no ultimo lugar nao tem honra nenhuma.......Vamos SONANGOL, vamos apostar numa estrela brilhante ,,,,,,eh obvio a todos quem ela eh.......NAO?!?!?!
Forca LUIS!!!
PS. A Nova Zelandia e a Australia oferecem campeonatos em Formula Toyota (NZ) e Formula 3 (AU) que sao excelentes vehiculos para os proximos passos no desenvolvimento da tua carreira pois muitos outros pilotos consagrados fizeram esse percurso.......(perdao mas eh a uma ideia)
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 12:21 am
Luis, os alunos da ESCOLA DE KARTING DE LUANDA desejamos te força e que nunca desististas, e isso foi o que nos disseste na aula que nos deste na nossa escolinha, esperamos te na volta a Angola
SEMPRE A ATACAR.
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 1:53 am
É isso mesmo, Francisco Valadão.
A SONANGOL, tem é que apostar no que ralmente é nosso e se ORGULHA de ostentar a nossa Bandeira.
Afinal de contas o qué Nacional é que é bom, como por exemplo a SONANGOL, só falta mesmo apostar num Nacional como o Luis.
Vamos lá Senhor Presidente da direcção da empresa, o Nosso Povo é capaz assim como a evolução da Sonangol com os nossos já é visivél e Respeitavél em tododo o mundo, se nos derem opurtunidades não precisamos dos de fora..
Um Kandandu especial para o Luis.
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 2:10 am
Se a nossa Unitel permitir, hoje a noite colocarei fotos da última prova do Luís.
Fazer uploads de imagens está complicado Sad
lss23
Número de Mensagens : 94
Data de inscrição : 11/11/2008
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 3:51 am
Agradeco a todos o apoio que me tem dado, pois tem sido muito importante para mim.
Conto com todos voces, nos bons e maus momentos da minha carreira, espero muito em breve dar-vos mais e melhores alegrias.
Estarei em Angola essa semana e irei ficar ate dia 1 de agosto, onde depois parto para Alemanha (para testar) e logo a seguir para Holanda (para correr).
Estaremos juntos na prova de Luanda.
Um kandando a todos.
Luis Sa Silva
(desculpem a falta d acentos, mas o meu portatil nao tem)
lss23
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 6:04 am
Citação :
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 7:20 pm
:Dance: Luis, xé Palanquinha
Não há duvidas, é precisso é cabeça, vais chegar lá e sem dares por isso. Ainda vais dizer: (como o tempo passa), escuta bem é o teu Kota e lembra-te, quanto mais se viver, mais sabedoria se tem " Assim dizem os nossos Anciãos, do passado e do presente.
Um kandandu com Bwê de Karga (as imagens estão excelentes e o Jorge parece estar muito bem).
Carlos (Kioko)
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 7:52 pm
http://www.art-motorsports.com/wordpress/?p=1167
lss23
MensagemAssunto: Re: LUIS SÁ SILVA   Ter Jul 14, 2009 8:32 pm
O formula acidentado era do piloto que vinha em 4 lugar (atras de mim) e deu um toque na traseira do meu formula (na 1volta da corrida), o que originou o despiste dele e a perca do meu 2 lugar a meio da corrida (pk mesmo depois do toque ainda tinha coseguido alcancar a 2 posicao).
(depois se for possivel, tentarei colocar um link com o video, ond mostra o toque / acidente do piloto)
Idade : 55
MensagemAssunto: Re: LUIS SÁ SILVA   Qua Jul 15, 2009 4:32 am
Aqui podem ver o carro do Luis que arranca em quarto, do lado direito da camara e passa logo para terceiro na curva no fim da recta da meta.
Depois o piloto em cujo carro esta instalada a camera bete no Luis e vai directo ao muro.
https://www.youtube.com/watch?v=OFfoLEg928c
LUIS SÁ SILVA
Página 2 de 18Ir à página : Anterior  1, 2, 3 ... 10 ... 18  Seguinte
Angola OffRoad :: DESPORTO MOTORIZADO :: O Desporto Motorizado pelo Mundo :: Angolanos em competição fora de Angola-
